Toffe007
Apr 15, 2023Aspirant
Is it possible to reserve/static ip adress on M1/Mr1100 a router
Is it possible to reserve/static ip adress on M1/Mr1100 a router - i only se hdcp on/off
michaelkenward
Apr 15, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Toffe007Apr 15, 2023Aspirant
Is´nt this a Nighthawk wifi 4g routers forum? I have a Netgear Nighthawm m1 or Mr1100 router.
- KitsapApr 15, 2023Master
Toffe007 wrote:Is´nt this a Nighthawk wifi 4g routers forum? I have a Netgear Nighthawm m1 or Mr1100 router.
No, it is not. This specific forum community is to discuss Nighthawk (AC) router (R6700 thru R9000 Series) products.
michaelkenward pointed you to the specific community for your hardware in his message above.
- michaelkenwardApr 15, 2023Guru - Experienced User
Re: Is it possible to reserve/static ip adress on ... - NETGEAR Communities
