leesteve
Jul 23, 2019Tutor
Is mr1100 a firmware upgrade possible?
I am currently using AT & T version but it is not available because it is used in other countries There is no webpage window to select an upgrade file so nothing is possible. Is there any other way?...
- Jul 24, 2019
Yes, it's possible.
Download the file (newest FW for ATT):
"MR1100-100NAS_23113828_NTG9x50C_12.05.05.00_00_GenericNA_01.02.secc"
and upload it using "fdt.exe".
More informations can be found on WWW.
nomad247
Aug 17, 2019Tutor
Hello, I have a similar issue and it was recommended I too upgrade the firmware. The message you posted said more info at www but there is nothing else after the www. I googled the info, found a site but have idea how to upload using the FTD unto my router, which works every well with one except. After charging it, and unplugging the charger, within an hour, it shuts down and I cannot power it up unless I remove tha battery and put it back in. I really like this router, too bad Verizon does not have one.
