jzz15
Feb 16, 2021Aspirant
Is MR5200 can support static IP?
Hi, on normal netgear router,I can set a a static IP for a device,like compuer or mobile phone,but in MR5200 5G Mobilke router,i can not set a static IP,becuase there no LAN settings in router setti...
michaelkenward
Feb 16, 2021Guru - Experienced User
Why do you want a "static IP"? Start there and look for other ways of achieving the goal.
For example, it is sometime possible to fix the IP address on the "client" rather than the router. But who knows if this will deliver what you want?
- jzz15Feb 17, 2021Aspirant
It is "Address Reservation" feature,I want set a static IP for a device,but in MR5200 settings,i cannot do this because it doesn't have this feature.
In attachment,it is RAX40 screenshot,RAX 40 have this feature.
- michaelkenwardFeb 17, 2021Guru - Experienced User
Why? (see above)
