RodPin
Feb 09, 2017Follower
Is netgear AC340U compatible with TPLINK MR3020 ?
I am looking to use my TP LINK MR3020 with a Netgear air card 340U to broadcast WIFI in my room . It's not getting connected and I am wondering if the devices are compatibles . it used to work with ...
NguyenDuy_0101
Aug 11, 2017Aspirant
You can follow the instruction and install the Goldenorb firmware bason on openwrt. It may be worked. My very old Netgear 782s is working perfectly now =))
