n3t
Sep 08, 2019Apprentice
Is the Nighthawk M2 able to charge its battery during operation?
My biggest gripe about the Nighthawk M1 is its inablitity to charge up its own internal battery while being used — unless you place it on a block of ice, that is. This is because it includes a te...
griffo3287
Jan 14, 2020Aspirant
So am I correct in thinking that even if the battery fully discharges over time while plugged into a wall socket (which seems to be happening), it will continue to operate on mains power? We are a very small home office and I wouldn't describe us as heavy users, but until I saw this post couldn't figure out why the battery charge was diminishing even when plugged into mains power.
W1lliam
Jan 15, 2020Virtuoso
when your battery is drained completely, suggest you to charge the battery with external charger as it will be taking long hours to re-charge it, if it still alive. When you have complete drained out battery inserted into M1/M2, it might still able to re-charge but that would take longer hours, even longer than external charger, as you are using the machine while charging it.
