SergioH
Feb 21, 2018Tutor
Is there a way I can force 3G on Netgear LB 2120?
I seem to have problems with the 4G connection, as the router disconnects constantly. Is there a way to force only 3G connection in the LB2120?
SergioH
Mar 01, 2018Tutor
Hi Jason,
The LB2120 is up to date, we checked for updates but it said it had the latest firmware.
JasonN
Mar 01, 2018NETGEAR Employee Retired
Hi SergioH,
Thanks for your response. Did you do a factory reset on the LB2120 after you updated it to the current firmware? If not, then please proceed with the factory reset?
Please let me know if this worked :]
- Jason N
