JustAWeeb
Aug 06, 2021Aspirant
is there a way to install a different frimware on my modem?
i want to install a different firmware onto my modem i have one on my moden called openwrt is there one i can flash onto my modem cause right now my modem uses the stock firmware and my carrier tmobi...
michaelkenward
Aug 07, 2021Guru - Experienced User
JustAWeeb wrote:
i want to install a different firmware onto my modem i have one on my moden called openwrt ....
Ask the people who write this third party firmware.
Netgear does not support moves like this which would invalidate your warranty.
- JustAWeebAug 15, 2021Aspirant
i use this modem i want to be able to use my datas unlimited plan cause paying extra for hotspot is just bad
- AyeAyeAyeAug 17, 2021ApprenticeNetgear is propitiatory firmware.
My M2 marketed by the network carrier made no mention of their version/firmware restrictions on the website or anywhere, I’ve been sold a dud Netgear M2 that won’t work well.
I’ve bought a 5G Android for £150 off Amazon that works better even on LTE than M2. There are apps (pdanet) you can use on Android that ensures data comes out your general not Hotspot.
EU net neutrality doesn’t allow a telco/net/carrier to do this now BUT the problem is if you highlight it to them they will force you off the grandad plan.
So Android and off you go... heres how
https://www.groovypost.com/howto/hide-data-usage-get-truly-unlimited-tethering-tmobile-one/- Potter45Aug 18, 2021Aspirant1.Verify that your router is compatible with the new firmware. The firmware that will be covered in these instructions is Tomato, since it is easily the most ...2.Download the latest firmware from Tomato’s website (either .7z or .zip format).3.Unpack it to a directory of your choice using a program such as winrar.
