DiVo
Dec 19, 2019Aspirant
Is there an AirCard 431U (Sprint) driver for MacOS Catalina (version 10.15)?
Is there an AirCard 431U (Sprint) driver for MacOS Catalina (version 10.15)? Was someone able to make the modem work on Catalina? Netgear, any estimations when the driver for MacOS Catalina would be ...
Blanca_O
Dec 29, 2019NETGEAR Employee Retired
Hi DiVo
Welcome to NETGEAR Community!
Please visit this link for Aircard 341U (Sprint) Software updates:
https://www.netgear.com/support/product/341U.aspx#download
Blanca
Community Team
- DiVoDec 29, 2019Aspirant
Hi Blanca_O,
Thank you for welcoming and your reply. Though, I'm a bit confused with your reply. Could you please elaborate a bit on what I should find on https://www.netgear.com/support/product/341U.aspx#download page? The way that page is shown to me, I only see there links to downloads of the drivers version 2.5.1 (which I mentioned does not work on MacOS Catalina) and version 2.3.0 (which I actually referred to as "some older driver version" without mentioning the exact version number). So, I have tried both and they don't work on Catalina. Did you referr to something else that should help me to get AirCard 431U working on MacOS Catalina and that I'm missing?
Thank you.
