JoanieD's avatar
JoanieD
Follower
Mar 02, 2017
Jetpack 791L distance to device
I recently bought the Jetpack 791L aircard from Verizon. I was checking out settings and I see that you can set the distance from it to the connected device and the choices are Short, Medium, Long. Does anyone know what those would be in feet? My husband will use this in his work and needs to know if he can leave the aircard in the vehicle or if he should carry it in his pocket. Thank you.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Too many variables to give exact ranges due to LTE service/signal, environment, interference, WIFI client specs etc... Easiest thing to do would be to test it out. Should be fine leaving it in vehicle if within 100ft but depends on environment.
    DarrenM
