ronjrrc's avatar
ronjrrc
JR 28x transmitter WiFi browser cannot connect to internet through aircard 762s
JR 28x WiFi recognises the aircard 762s as having a very strong signal. Tapping the transmitter screen to activate and authenticate the aircard connection the 28x goes through the connecting process ...
  • DarrenM's avatar
    Aug 19, 2015
    Hello ronjrrc
    From what I have looked up on the JR 28x that it is running android 4.2 have you tried to have the device forget the network and then try to reconnect to the aircard? it could have some bad settings saved for the aircard not allowing it to connect. Hope to hear your feedback.
    DarrenM
