kadhav
Jan 29, 2024Aspirant
Just hooked up orbi 970
I just hooked up my new 970 and two satellites and it seemed as though the satellites were dropping signal pretty frequently. I was playing PlayStation and would continuously get kicked from games ra...
michaelkenward
Jan 30, 2024Guru - Experienced User
What's the exact model number? 970 looks like the back end of a complete model number. It also smells like an Orbi device, as you have put in the subject, which is nothing like the Cell Service Mobile Hotspot Modems, AirCards, & Mobile Routers.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
You might like to search there for messages related to your issue.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
