Cliffgi's avatar
Cliffgi
Follower
Apr 19, 2020
Keeping the MR1100 Nighthawk Cool
As you may be aware, the MR1100 Nighthawk M1 tends to run a bit hot. To make things worse, the users guide list the the max operating temprature as 40c, 104f. Place it near a window for better reception an you will likely have overheat issues like me. I have fixed this problem for myself and thought perhaps others maybe interested. I designed and 3D printed a holder that sports a USB powered fan. My needs are fixed, that is, I don't travel with the M1 often. At home it is the only internet connection I have available. Rural living gets no tech love, as is whitnessed by SpaceX's StarLink deployment strategy; tout desperate need for rural service, but plan first deployment to all major metro areas rich in options. My prediction is that rural areas will never see it. BUT, I digress!  If interested in a heat solution for the MR1100, my design it is available for free on Thingiverse. Just search for MR1100 or B-Kool. I'm working on a one-piece tabletop version and will also list it there in a few days, once complete.
Cheers!
  • Have you tried 3D printing some sunglasses and tatoos for the MR1100 to make it "cooler"?
    Also, consider removing the battery and getting an external USB battery.
