mkew
Feb 15, 2017Aspirant
LAN support on new MR1100 router
Hi there, The new MR1100 device looks great. Just wondering if: a) Does it support LAN networking between connected devices? b) Does it allow devices to connect and network even if there is no...
- Feb 24, 2017
Hi,
The MR1100 ethernet interface supports both LAN and WAN modes.
By default, the ethernet interface is in LAN mode on the same subnet as the WiFi interfaces.
When put in 'ethernet offload' mode, the ethernet interface is reconfigured as the WAN interface and LTE data connection is disabled.
The LAN interfaces are operational even when WAN interface is disconnected.
Steve
DarrenM
Feb 17, 2017Sr. NETGEAR Moderator
Hello mkew
here is the user manual for the device may help with what you are asking.
http://www.downloads.netgear.com/files/GDC/MR1100/MR1100_UM_EN.pdf?cid=wmt_netgear_organic
DarrenM
