notawnewbie1's avatar
notawnewbie1
Follower
Mar 31, 2023
LAX20 - missing/broken features
The documentation implies that:
You can enable/disable wifi using the web interface for the non-guest wifi networks.  No such option found.
You can enable/disable remote administration.  Page in router where option is supposed to be contains no such option.
The blocking schedule - based on the information displayed on the router web page, you cannot disable the blocking schedule, you have to block access for at least one minute for a day.
H/W: LAX20
F/W: V1.1.6.34_2.0.52
Please fix.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    How is the LAX20 configured and connected to the Internet? Some sort of modem/gateway/ONT as well as the mobile connection?
    What firmware version is it running?
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Cell Service Mobile Hotspot Modems, AirCards, & Mobile Routers - NETGEAR Communities
    Those things are very different from the standard Netgear routers covered in this section.
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
