radicaldoc
Sep 16, 2023Aspirant
LAX20 and OPENVPN/NORDVPN
hi i am just about to buy a new nighthawk LAX20 but what is stopping me is whether you can setup a good VPN on it. i have Nordvpn can this be used easily?? without re-flashing the actual LAX20 ?? th...
radicaldoc
i need to know if you can have a vpn on the LAX20 and if it's easy to use with it does someone know????
Sep 16, 2023Guru - Experienced User
support.nordvpn.com
- radicaldocSep 16, 2023Aspirant
i take it you have no idea then...simple question really is the VPN on the LAX20???
or any VPN actually on the LAX20. Is it built in?? just add credentials or not .why would i want to ask NORD if it has it built into the firmware????
- FURRYe38Sep 16, 2023Guru - Experienced User
Again, something to ask them about. They will know.
again why would i ask them about your product and whether netgear lax20 has inbuilt VPN capability???
if you don't know say so...
this isn't a hard question and you are the guru..... but cannot give a simple answer.
have a good one.
saludos
