BHL315
May 12, 2021Aspirant
LAX20 Bridge mode
I needed a LTE modem that had the possibility to operate in bridge mode, so after some searching I came across this link: https://kb.netgear.com/31163/How-to-change-4G-LTE-Modem-from-router-mode-...
BHL315
Picture didn't seem to work, trying again.
Attatching it instead of putting it in the reply.
- Blanca_OMay 25, 2021NETGEAR Employee Retired
Hi BHL315
I got an update from the team.
LAX20 does not support bridge mode for LTE. The LAX20 user manual has bridge mode instruction but that is for wireless bridge mode and not for LTE.
Blanca
Community Team- BHL315May 26, 2021Aspirant
Thank you for your answer! Weird how the "regular" support could not give this information in a timely manner.
As you can clearly see in the picture, it previously stated that it in fact did have support for the kind of bridge I'm
looking for and that was the sole reason we went for this particular model (aside from 4G / LTE).
Now what?
I've been talking with the support for so long without getting this answer that I can no longer return it, it is sadly useless
for us at this point and I would like my money back. This has created months of problems for our small company.
Best regards
- CybertaxJun 01, 2021Aspirant
Hi Blanca_O,
does the LAX20 support the so called WISP or EXTENDER Mode to take internet connection from a WIFI Hotspot and share it over the LAX20's own WIFI? If yes, is it possible over 2.4 GHz and/or 5 GHz?
Thank you for your help!
Ralph
- Blanca_OJun 03, 2021NETGEAR Employee Retired
Hi Cybertax
Welcome to NETGEAR Community!
You can wirelessly bridge LAX20 to another router to connect multiple devices at the faster WiFi speed. You can specify the settings of the other router to which this router will connection (2.4GHz or 5GHz).
To know more, please check this reference:
[page 87 - 88]https://www.downloads.netgear.com/files/GDC/LAX20/LAX20_UM_EN.pdf
Blanca
Community Team
