BradWr
Feb 20, 2023Tutor
LAX20 Dropping LTE Internet Connection and Requiring Reboot Multiple Times a Day
I'm using a Netgear Nighthawk LAX20 with the SIM card as the primary/only internet connection. Verizon is the carrier. This is in a rural area with nearest tower 2.2 miles away through the woods. Mul...
MissyC2000
Feb 22, 2023Initiate
I am having the same issue out of my Netgear Nighthawk LAX20 with LTE only with Verizon. It drops the signal multiple times a day and I have to reboot it, which makes it almost useless for working from home effectively. I have already had it replaced once under warranty when the original router stopped reading the SIM card slot altogether 4 months after I bought it. I have had it less than 1 year. Does anyone know what would cause this and how to resolve it? Moving the router to a different location or adding an antenna outside of the house to it have done nothing to help.
- Blanca_OFeb 22, 2023NETGEAR Employee Retired
Hi BradWr and MissyC2000
May we please have the following information:
- What is the firmware version
- Internet LED status if issue re-occur
- Kindly describe your Network Topology
- Type of data plan from Verizon
- APN Settings (Is it the default setting from Verizon? )
--- Here's a reference of how to view and/or configure APN settings: https://kb.netgear.com/31166/Looking forward to your response.
Blanca
Community Team- MissyC2000Feb 23, 2023Initiate
Blanca, below is the information you have requested for troubleshooting:
Firmware Version - v1.1.6.34
Internet LED status if issue re-occur - LTE LED light turns red when signal drops
Network Topology - Netgear Nighthawk router using 4G/5G Verizon LTE only providing wireless signal to 2 work laptops in the same room roughly 5 feet away. The router sits on a wooden cabinet away from any interfering signals like TV or phones. It gets a strong signal (35-40 down and 4-7 up) when connected.
Data Plan from Verizon - 150gb of 4G/5G data per month specifically assigned to Netgear Nighthawk router via IMEI
APN Settings - Default from Verizon with:
APN Value - VZWINTERNET
No User Name, No Password, PDP = IPv4v6
Please let me know if you need more information. Thank you.
Melissa Carlton
- Blanca_OFeb 23, 2023NETGEAR Employee Retired
- Swade777May 18, 2023InitiateHaving the same problems after rebooting every day, I'm ready to take a hammer to this router!!!!
