BradWr
Feb 20, 2023Tutor
LAX20 Dropping LTE Internet Connection and Requiring Reboot Multiple Times a Day
I'm using a Netgear Nighthawk LAX20 with the SIM card as the primary/only internet connection. Verizon is the carrier. This is in a rural area with nearest tower 2.2 miles away through the woods. Mul...
Blanca_O
Feb 23, 2023NETGEAR Employee Retired
BradWr
Feb 23, 2023Tutor
How about you share it with all of us since there are multiple of us having this issue?
Also I've validated with a Netgear dealer that the Nighthawk isn't up to this environment. Time to look at something more commercial grade.
brad
- BradWrApr 09, 2023Tutor
Fixed it. Throw out the Nighthawk and get something commercial grade like the Peplink BR1. In these situations where you have very limit LTE connectivity with high noise you need something with the processing power to deal with it like your iPhone does. The Nighthawk doesn't have the power. the BR1 does although it's 5x the price of the Nighthawk. Just upgraded to the BR1 with nothing different and having rock solid connectivity and continous uptime.
brad
