Bonderz
Sep 03, 2022Aspirant
LAX20 Poor WiFi signal
I have a AX1800 LAX20 AX6 Router and the WiFi outputs -90DB within the same room. Anyone had this before? The ethernet works great but the WiFi is unusable. Regards, George
michaelkenward
Sep 03, 2022Guru - Experienced User
Bonderz wrote:
I have a AX1800 LAX20 AX6 Router....
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
