Bonderz
Sep 03, 2022Aspirant
LAX20 Poor WiFi signal
I have a AX1800 LAX20 AX6 Router and the WiFi outputs -90DB within the same room. Anyone had this before? The ethernet works great but the WiFi is unusable. Regards, George
Blanca_O
Sep 05, 2022NETGEAR Employee Retired
Hi Bonderz,
Please provide router's firmware version.
Is it affecting all of your Wireless devices? What are these devices?
What is your Subscribed speed? Expected speed? Actual speed?
If you haven't tried factory resetting the router, please do so and observe the connection.
Blanca
Community Team
- BonderzSep 19, 2022Aspirant
Hi Bianca, I am running the latest version of firmware available. It's all devices unfortunately and I have tried a factory reset. My broadband speeds are correct. Its the distance of the WiFi that is the issue. The signal broadcasted does not cover more than 10ft and the device is meant to cover 1600ft?
Best Wishes,
George
