maxFerr's avatar
maxFerr
Lax20 turn off wps functionality
Hi,
Can I turn off/on the WPS functionality on Lax20 by ad in interface , or in any other mode?
Thanks
    maxFerr wrote:
    Hi,
    Thanks
    I don't see a setting for you to be able to disable it.
  • FURRYe38's avatar
    Might check the routers web page under advanced tab/advanced settings/Wireless settings and see if there maybe a check box. WPS is only activated if the WPS button is pressed on the router.
    maxFerr wrote:
    Hi,
    Thanks
