Brookeville
Dec 15, 2017Aspirant
LB-1120 Bridgemode firmware Fix NEED UPDATE
Hi All NetGear posters with history of this model not working correctly for bridging function with original firmware. ***Need a heads-up*** now that Netgear Firmware fix has been available for a fe...
bossss7
Dec 16, 2017Aspirant
Hi,
I can't comment on the LB1120, however it's cousin, the LB2120 (Australian version) now works perfectly in Bridge mode. I'm assuming you're in the North American region, which as I understand from another thread, got the new firmware ahead of the EU and and AUS regions, so all should be good.
Just FYI, the LTE provider I use doesn't provide public IPs, rather it gives NATd private IPs. This is the configuration most people were struggling so I thinkif you get a public IP, it should work with any type of firmware.
- BrookevilleJan 16, 2018Aspirant
I'm trying to setup remote video monitoring of a DVR/NVR network. The only Internet service available is Verizon LTE. I purchased Verizon (NovaTel) "Mi-Fi" LTE router to get the SIM card programmed on their system. My DVR manual indicates that I can either use a static IP (VERY $$$) or I can use DDNS where DVR has abaility to "reach out to changing IP addresses, so, I would want to use DDNS and implement LB-1120/2120 in bridge mode connected to new WI-FI Router. Your thoughts?
