Dar1967's avatar
Dar1967
Follower
Mar 09, 2021
LB 1120 no internet
I have a netgear LB1120 with linksys 12299 router using straight talk ATT SIM card, power light an 2 signal bars are green, also light on far right is flashing green but still on internet using Ethern...
  • Blanca_O's avatar
    Apr 13, 2021
    Hi Dar1967,
    Welcome to NETGEAR Community!
    Kindly disconnect the Linksys router and the LB1120. Then wired a computer to the LB1120 so we can check if it has Internet access.
    Also, the five LED bars indicate the signal strength of the mobile broadband service that the modem is connected to. Five green bars indicate the strongest signal. One green bar (that is, the shortest bar) indicates the weakest signal. Please position the LB1120 where it can receive a strong 4G LTE signal.
    Blanca
    Community Team
