GrizzlyBear865
Feb 19, 2021Follower
LB 1120 power light keeps blinking
My power light keeps going between amber and green. I’ve checked the SIM card multiple times and I’ve also reset it. I just got this and get get it to keep connection. It shows 3 to 4 bars but will not fully connect. The only thing I can find on it is that it’s the sim car
1 Reply
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
