iroody
Jun 19, 2017Aspirant
LB1110 bridge mode with unifi USG
Hi, I am trying to setup a unifi USG behind my LB1110 modem. When I set the modem to bridge mode, the USG has no internet access and when I set the modem to router mode, I get a double NAT. Anyo...
netwrks
Jun 19, 2017Master
Did you reboot the modem after changing to bridge mode? Reboot modem, wait until the modem comes back online.
Power up your USG and follow the setup: https://dl.ubnt.com/guides/UniFi/USG_QSG.pdf - The assumption is you have a Unifi Controller. Don't use the same subnet that is on the LB1110 on the USG..
iroody
Thank you for your answer, yes I did reboot the modem.
LB1110 is using; ip 192.168.5.1 and Netmask : 255.255.255.128
USG is using 192.168.99.1 and Netmask 255.255.255.0
I am using the newest version of Unifi controller and the setup is as described in the PDF.
