iroody
Jun 19, 2017Aspirant
LB1110 bridge mode with unifi USG
Hi, I am trying to setup a unifi USG behind my LB1110 modem. When I set the modem to bridge mode, the USG has no internet access and when I set the modem to router mode, I get a double NAT. Anyo...
iroody
Thank you for your answer, yes I did reboot the modem.
LB1110 is using; ip 192.168.5.1 and Netmask : 255.255.255.128
USG is using 192.168.99.1 and Netmask 255.255.255.0
I am using the newest version of Unifi controller and the setup is as described in the PDF.
netwrks
Jun 20, 2017Master
Found this llink on the UBNT site. Not clear if it's a USG or LB issue. You may have to dig further on the UBNT site.
- iroodyJun 20, 2017Aspirant
Hi netwrks,
I will check this solution, because I am not an IT professional I want to avoid adding codes that I cannot understand. I have started a thread on the unifi community and this might be a good answer:
- netwrksJun 21, 2017Master
From your Unifi thread, seems clear that the USG does not support IPPT, but does support PPoE. So, the question is, do you return the USG, or seek an ISP that has a modem that supports bridge mode, and can be bridged.. I haven't really spent time looking at LTE modems, and haven't wrapped my head around them..
- iroodyJun 27, 2017Aspirant
Yes, hopefully this will be solved soon. Until then, I only have one VPN port, so I will forward it twice :)
