RadekB
Nov 24, 2016Aspirant
LB1110 radio band selection
Hi All, I'm new to the community, so sorry in advance for any mistakes done :) I just bought LTE modem/router LB1110. The most important thing for me is to be able to select fixed radio band (8...
RadekB
Hi All,
It seems I managed to add correct entry based on following article: http://forums.whirlpool.net.au/archive/2515438.
Best regards,
Radek
lteparanoia
Feb 05, 2017Aspirant
Defining own BAND entries first requires entering a proper entercnd password. What is the password, if you know it? You can PM me.
- lperomaAug 27, 2017Aspirant
Hi there,
I also really need that default password for the AT commands, I need to use 1800MHz band (B3), that's not congested.
Thanks!
Hi there,
just found the answer:
at!entercnd="granville"
Enjoy!
- bmanning81Feb 18, 2018AspirantHi is this for the LB1110 or LB1120?
