vacool
Oct 04, 2016Follower
lb1111-100eus PoE standard
Is it 802.3af compliant? If so, is it better to use 48V PoE Injector (like Linksys LACPI30-EU) or connect supplied adapter via PoE adapter (like Mikrotik RBGPOE). By the way, LB1111-100EUS is not...
DarrenM
Nov 22, 2016Sr. NETGEAR Moderator
This can be powered via adapter or POE
DarrenM
gruntpartystyle
Nov 22, 2016Aspirant
And the question is again, what PoE standard... passiv? 802.11af?
- DarrenMDec 15, 2016Sr. NETGEAR Moderator
LB1111 supports the 802.3af PoE standard.
DarrenM
