Tellurium
Aug 05, 2017Apprentice
LB1111 Feedback - Need prefered cell ID list
Hello I bought a LB1111 LTE modem, I’m actually satisfied with the performance and stability of the device BUT, there are 2 key feature missing: 1. In my area there seems to be 2 LTE antennas f...
Tellurium
I forgot another detail.
Please stop using bulky TS-9 antenna connectors on device like the LB1111 without battery and that are not intended to be carried around like the battery powered Aircards. Use SMA connectors instead. They are much more robust and it avoids the adding of a TS-6 to SMA adaptor, which deteriorates the signal.
Tellurium
Aug 13, 2017Apprentice
Up please :o
