rfx
May 18, 2017Tutor
LB1111 not starting after Poe power loss
When i power the LB1111 via PoE everything works fine as long as i done unplug the netwok-cable an replug it into the netwok port. the lb1111 doesnot power on. i have to depress and press the power ...
rfx
Jul 03, 2017Tutor
I had to do an RMA. I have a second device so the problem was easy reproducable. The PoE part of the LB1111 seems to be crappy.
VincentNguyenQu
Jul 03, 2017Star
So the unit you got in exchange did not exhibit this problem, or is this a problem which affects all LB1111 (and you simply got a refund) ?
If I go through Amazon to replace it, I might get another unit which exhibit the exact same behaviour ...
Regards
- rfxJul 03, 2017Tutor
The unit got exchanged and now it works.
i did googling before i contacted netgear and found some user-reports that the poe of the device seems sensitive to cable-length, cable-type,...
But now my two units seem to work.
But this does not help with the fact that the device is not a very good lte-modem. the signal on nearly any other device i have is way better.
- VincentNguyenQuJul 03, 2017Star
Thanks for this information, I'll check on my cabling
What other LTE modem are you using (if you are allowed to disclose it) ?
Regards
Huawei B593s-22
Far from perfect because it is not able to do bridging and does weird things with sip-traffic when you do not know how to configure it right but the weak-signal performance is much better. even with very strong signal i get better pings.
i also tried antennas on my lb1111 but i was not too impressed with the performance also. but this may also be the fault of the cheep cineese-type antenna.
LB1110/LB1111 is only an option when you need bridging - in my opinion. for that its a good device
