rfx
May 18, 2017Tutor
LB1111 not starting after Poe power loss
When i power the LB1111 via PoE everything works fine as long as i done unplug the netwok-cable an replug it into the netwok port. the lb1111 doesnot power on. i have to depress and press the power ...
VincentNguyenQu
Jul 03, 2017Star
Thanks for this information, I'll check on my cabling
What other LTE modem are you using (if you are allowed to disclose it) ?
Regards
rfx
Jul 03, 2017Tutor
Huawei B593s-22
Far from perfect because it is not able to do bridging and does weird things with sip-traffic when you do not know how to configure it right but the weak-signal performance is much better. even with very strong signal i get better pings.
i also tried antennas on my lb1111 but i was not too impressed with the performance also. but this may also be the fault of the cheep cineese-type antenna.
LB1110/LB1111 is only an option when you need bridging - in my opinion. for that its a good device
- VincentNguyenQuJul 03, 2017Star
Thanks for these details
Yes I do need bridging, as I use the modem as a secondary ISP on a load balancing setup. I don't use the router part (although practically, given the LTE ISP operates as a double NAT, I could probably operate in a triple NAT setup, but I'd rather not test it).
I'll set it up in an external box, but it might be good to RMA the unit first
- rfxJul 03, 2017Tutor
if you connect it to a poe switch with a short cable (eg. 0.5m) id should light up within seconds. otherwise you should exchange ist.
my defect unit did start sometimes after many minutes.
when its not starting within about 10s then you shold do a RMA.
