ivanmorato
Jun 11, 2021Aspirant
LB1120 - Mobile Broadband Disconnected
LB1120 Mobile Broadband Disconnected My modem presented with Mobile Broadband Disconnected after a short time (1+ days). The ONLY way to un-do it is to do a Factory Reset. I haven't done any...
Blanca_O
Jun 13, 2021NETGEAR Employee Retired
Hi ivanmorato
Welcome to NETGEAR Community!
Please provide the firmware version of the device.
You mentioned that you have multiple LB1120 modems and some are having the same issue. Is it on the same ISP?
Who is your Internet Service provider?
Were you able to call your Internet provider to check if you have the correct APN information and right data plan?
Blanca
Community Team
ivanmorato
Jun 17, 2021Aspirant
Firmware Version: M18Q2_v12.09.163431
App Version: NTG9X07C_12.09.05.30
Hardware Version: 08
I have already tested it with apns(T-Mobile, Telefonica, ATT) and I have the same problem.
The modem only works again when reset.
