Konrad999
Dec 29, 2020Aspirant
LB1120 and Nighthawk X6S dont work together
I just got a LB1120 and put a verizon sim card in it. I set it to bridge mode I plug in my computer to the ethernet port and works fine. I plug in my phone to the ethernet port (using usb c to ethe...
Konrad999
Dec 30, 2020Aspirant
I want to thank you. I finally was able to fix my issues.
The moment you mention "set your router as an access point and set the modem as the router" I immediately made the changes
I reset the modem one more time and plug in the X6S to the modem but again as an access point, it did not work SO I plugged in the N600 back into the modem and it works as I previously tested it. THEN I plugged into the X6S directly into the N600. I turned off wireless on the N600 and enabled wireless on the X6S and it works fantastic. The X6S continues to be an access point now
My wireless devices still pick the great signal from the X6S and my wired devices are plugged into the N600 and all work great plus now I have more ethernet ports for the future.
This is not the cleanest setup but it works
Thanks again
michaelkenward
Dec 31, 2020Guru - Experienced User
This does not convince me that you put the R7960P into access point mode as the manual describes it.
AP mode is not a case of simply plugging the R7960P into the modem. You do the AP thing in the graphical user interface (GUI) on the R7960P. But there is an important wrinkle. You have to do things in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
We still don't know what this N600 might be. (Like X6S it is a wifi speed indicator and not a modem number, with hundreds of N600s and dozens of X6S devices out there.)
We do know that the N600 is old. (They stopped making them years ago.) Which means that it may not have the GUI approach to turning it into an AP and you won't find instructions in the the manual for the device. So we have no idea what mode the old router is in.
