rramse
Jul 22, 2018Aspirant
LB1120 antenna overkill?
Okay, first of all, I don't have any complaints about the Netgear internal antenna performance. It works okay inside one house but in another house I need to run an external antenna because of c...
- Sep 06, 2018
Hi rramse,
We received a feedback from the team. It would be best to check with FCC and Local Government regarding regulations when it comes to using of these type of antennas. We cannot really answer on behalf of FCC.
Blanca
Community Team
Blanca_O
Jul 29, 2018NETGEAR Employee Retired
Hi rramse,
Welcome to NETGEAR Community!
Let me check this with the team. We'll get back to you.
Blanca
Community Team
- Blanca_OSep 06, 2018NETGEAR Employee Retired
Hi rramse,
Blanca
Community Team- rramseSep 09, 2018Aspirant
Thank you for taking the time to check with your team and supply a response. Not all manufacturers are as courteous to their customers as Netgear. However, I still need to know the transmitting power output of the LB1120. It's not listed anywhere I can find.
Maximum Power from Intentional Radiator *1
Maximum Antenna Gain (dBi)
EIRP (dBm) *3
EIRP (watts) *3
30dBm or 1 watt
6
36
4
29dBm or 800mW
9
38
6.3
28dBm or 630mW
12
40
10
27dBm or 500mW
15
42
16
26dBm or 400mW
18
44
25
25dBm or 316mW
21
46
39.8
24dBm or 250mW
24
48
63
