clydeml
Jun 12, 2017Aspirant
LB1120 Antenna
Two quick questions about antennas. I have an LB1120 modem, first question; can I attach two antennas or just one? second question, if I can only attach one, do I need to use both TS9 connectors? ...
vronp
Jul 12, 2017Guide
Thanks very much for the very informative reply.
I like the approach you took and it seems very cost effective compared to what I have seen.
My only worry is that I need Band 12 (B12) support. The LB1120 supports it and it's on the 700 MHz spectrum.
Did you use off the shelf mounting hardware to get the proper mounting angles? If so, would you mind posting part numbers?
Thanks again for the great post.
