clydeml
Jun 13, 2017Aspirant
LB1120 Antenna
Two quick questions about antennas. I have an LB1120 modem, first question; can I attach two antennas or just one? second question, if I can only attach one, do I need to use both TS9 connectors? ...
vronp
Jul 12, 2017Guide
You should find a drain hole in the antenna case. I have one on the single enclosed Yagi I have. I believe that is the only reason the antenna has an Up/Down sticker. In any event, I agree with you.... 135 and 315 should be the same I feel....
I would mount so that the drain hole is down.
Garyzx
Sep 09, 2017Aspirant
So your using to of the same antenna's, how are you connecting them to the modem. One to main and the other to div?
