clydeml
Jun 12, 2017Aspirant
LB1120 Antenna
Two quick questions about antennas. I have an LB1120 modem, first question; can I attach two antennas or just one? second question, if I can only attach one, do I need to use both TS9 connectors? ...
countrywidewifi
Nov 28, 2017Tutor
just got a LB1120 and currently using it with the netgear mimo antenna. looking at mounting an outdoor mimo antenna to help with the signal. would the LB1120 beable to drive http://www.altelix.com/698-2700-MHz-Dual-Polarized-MIMO-Panel-Antenna-p/as0727g10b65m2-nf.htm
or https://www.amazon.com/dp/B01NBSLNJ6/_encoding=UTF8?coliid=I1VATEDV5YSMK&colid=2HLK84OXHSD3C the proxicast mimo antenna?
