jmbones's avatar
jmbones
LB1120 Antenna
What is the difference between the main port and the "div" port? Do both need to be used?
Anyone have a successful setup with external antennas and 25' run of coax cable to the LB2120 in your house? Care to elaborate on your up/down speeds and what equipment you're using?
Thanks!
1 Reply
