kassamasif
Feb 02, 2021Aspirant
Lb1120 can't connect with Verizon properly
Hi, just purchased a netgear lb1120 and put a Verizon sim card in. All lights are green and I get 2-3 bars. I can load Google and make searches but am unable to open up any websites. Nothing other the...
michaelkenward
Feb 03, 2021Guru - Experienced User
kassamasif wrote:
I can load Google and make searches but am unable to open up any websites. Nothing other then Google searches.
Sounds like a problem with the local network setup.
What do you have connected to the Lb1120?
What are you using to connect to the outside world to make those Google searches?
kassamasif
Feb 03, 2021Aspirant
I have a tplink router ltwr841n and using my netgear lb1120 with a Verizon prepaid unlimited account.
- michaelkenwardFeb 03, 2021Guru - Experienced User
kassamasif wrote:
I have a tplink router ltwr841n and using my netgear lb1120 ....If you are running the two in tandem, then you have two things trying to be the network's router. That way madness lies.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
It may be possible to put the lb1120 modem/router into modem only (bridge) mode and then to use the second device as the router. Sometimes it is easier to put the second router, the ltwr841n, into AP mode. But that has its own drawbacks.- kassamasifFeb 03, 2021AspirantEven if I connect the lb1120 directly to the computer same problem. I tried bridge mode originally and nothing helped when I hooked up the tplink.
