6DoF
Jul 15, 2020Follower
Lb1120 dropping internet
Worked great for a while, and works great when working. I have used it on 3 different networks even. VZ, AT&T, T-Mobile, then back to AT&T all in a few months. Now 1-2x a day it drops connection and n...
Gbalboni
Oct 24, 2020Aspirant
Has anyone found a solution to this? I am having the same problem. ATT is the carrier and the LTW is our sole internet aceess. What happens is that the LB1120 modem maintains the connection, but the RT-AX88U router drops the connection to the modem. When this occurs, the router log has an entry "WAN Connection ISP's DHCP did not function properly". I made the following tweaks which have helped. It dropped only one time yesterday - instead of the 10-15 times a day before the tweaks. In the LB1120 - I turned off "keep alive". In the Asus router in the WAN tab - I set the DHCP query frequency to "normal mode". - We will see if this works or if there is some other setting buried in one of the devices.
