gearfly's avatar
gearfly
Follower
Sep 12, 2020
lb1120 dropping speed
Added lb1120 and startedusing with 72.5 mbps then dropoff to 14.3 then to 9.29. 20 minutes later it jumps back to 69.2. Any ideals on what would be causing this?
1 Reply
  • I was just seeing if you have found a solution to this? I have a similar issue. I have 4-5 LED bars, and my speeds will go from 20Mbps down to 500Kbps down and then jump back up to 60-100Mbps down.
