bfein's avatar
bfein
Follower
Nov 18, 2019
LB1120 Extremely Slow: 1-3 Mbps with strong signal on T-Mobile AND Verizon in Los Angeles
Recently bought a LB1120 and the upload/download speeds are absysmal, extemly slow compared to iPhones running on the same networks adjacant to the modem. I'm only getting between 1-3Mbps with a few peaks of 10Mbps occasionally, both on verizon and t-mobile networks. Already reset the modem several times and updated the firmware on it. Relativly good signal, between 2-4 bars. At a loss for why it's SO slow, I'm in metro Los Angeles.
Before I try a warranty claim, anything else I can try? I have an external antenna on the way to try.
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi bfein
    Welcome to NETGEAR Community!
    Data transfer speed depends on signal strength and interfering radio sources such as electrical generators or WiFi devices.
    Please check the network type (for example, LTE 4G is generally faster than 3G).
    Blanca
    Community Team
