sdavis97's avatar
sdavis97
LB1120 extremely slow
Hello, I have a LB1120 with a Google Fi SIM. I have put in the APN and have a 5 bar connection. Its has connected to B2 and Band 12 in two different locations and I get the same poor 50 something KBit speed test. It can't even download the 53mb firmware update before erroring out at 7%. Is there someway to upload the firmware update seperatly that may fix it, or some other fix?
  • Nevermind, turns out it was because the sim wasn't activated even though I could swear I had.
1 Reply
