verge999
Jul 11, 2020Tutor
LB1120 intermittent DNS issue
My LB1120 worked flawlessly for around 6 months, but recently has begun to exhibit odd DNS behavior around twice a day. At those times, open sessions (VNC, video and audio streaming, etc.) will c...
bkibler
Aug 31, 2020Aspirant
I have the exact same problem. DNS typically works for about 6 hours (although sometimes as short as 2 hours), and then stops working. I can work around it by forcing my laptop to use a dedicated DNS server, but that's really annoying, and I'd just like DHCP to work properly through the router. Or I can reboot the router, and then it works again. Doesn't appear to be a hardware problem, as bypassing DNS works.
