plympton
Feb 27, 2021Aspirant
LB1120 latest firmware causes Mobile Broadband Disconnected
I have had a very, very reliable LB1120 that I use as a failover LTE connection. It is set to always be connected, pinging something every 15 minutes per the Firmware UI. I noticed a firmware updat...
plympton
Mar 04, 2021Aspirant
I factory reset the device, and it started working again. Since I crafted my network around the default behavior of the device, I was able to use it again. After ~ 5 days it stopped working again. A reboot doesn't do anything. There are no options to re-connect the device. I performed a factory reset again (not touching the SIM, as I am physically remote), and it worked again.
Here is a screenshot immediately after a factory reset. It promptly re-connected and started working again. Since I'm using this device as a backup connection if my primary connection fails, this is no longer a usable device.
