Globalmet
Mar 06, 2018Aspirant
LB1120 led status
Hi, i have a 4G LTE Modem LB1120 and i it was working fine but yesterday noticed that the first led (power led) changed from green to amber color but its weird because i have three green signal stren...
- Mar 07, 2018
Hi Globalmet,
Please also check if your LB1120's firmware is up-to-date with the most current firmware. :]
- Jason N
Globalmet
Mar 07, 2018Aspirant
Hi, thanks for the reply, the first led (power led) is solid amber and i have three green led signal strength. The problem is that the router is so far from me, i installed in the mountains for a weather station, it has an external antenna and everything was working fine until the led change from green to amber and i cant get the meteorological data. I think I'll have to go to the mountain and pull out the sim card
JasonN
Mar 07, 2018NETGEAR Employee Retired
Hi Globalmet,
- Jason N
