Manav77
Feb 28, 2020Follower
LB1120 Model on Tmobile and ATT
Hi, I purchased LB1120. I have put in AT&T sim, I see all bars. It shows 3G symoble on dashboard, however I am not able to connect to Internet. I put in T-mobile sim card and there are no bar...
Blanca_O
Apr 05, 2020NETGEAR Employee Retired
Hi Manav77
Welcome to NETGEAR Community!
What is the device SKU (e.g. LB1120-xxx)?
Kindly reset LB1120 to factory default settings. You can use either the Reset button on the back of the modem or the modem’s web pages. However, if you cannot find the IP address or lost the password to
access the modem, you must use the Reset button.
Blanca
Community Team
