pthrift5001
May 12, 2020Follower
LB1120 Modem
Does the modem provide WiFi as well or does it require a router?
Denzien
Jun 10, 2020Aspirant
This does not have wifi built into it. You can however plug in a wireless access point through the lan cable. Also if you have a wireless router that you prefer to use, you can just use it as a modem.
