Jakedecamp
Mar 27, 2020Follower
LB1120 No Connectivity
Hi. I have an LB1120 for my home internet because I live in a rural area. It has worked fine for about a year & yesterday just stopped. Did a factory reset multiple times with no luck. None of the con...
JohnPeng
Mar 27, 2020NETGEAR Expert
Based on the message, it is related to your AT&T data plan. Could you please check with AT&T on your account or try the SIM card on another device to see whether it works?
Thanks
