Dop88's avatar
Dop88
LB1120 Not connecting to a cell tower
I purchased the NETGEAR 4G LTE Broadband Modem LB1120 along with a TP-LINK WiFi Router AC1750 to access a 4g LTE tower that is in visual distance of my location. I will be using it in a rural area and accessing it periodically. The tower as far as I know services AT&T, US Cellular, Sprint and possibly T- mobile. I have Verizon as my cell service and only get 1x. I have teathered off others cells and been successful which gave my the available 4g LTE services for that tower. The signal is strong as I stated on cell phones. The tower is visable probably less than a half mile away. My problem is I have tried sims from T mobile, AT&T and US Cellular. They connect at the local store before I leave but when I get to the location none have worked. Solid amber light on LED. The sims are monthly pay as you go data only. Is there something else I should be doing?
  • We have had great access for two years, but this summer, we have had access issues sporadically (every 2 weeks).  Nothing appears amiss, but the amber light remains, then suddenly turns back to green (3 - 4 bars strength).  I see you have not received any suggestions so far.  We will be monitoring your activity.  Have you received any feedback from the seller? Do you have any suggestions for us? Thank you.
    • Dop88's avatar
      Dop88
      Thanks for replying. Have not resolved the issue or received any direction on this. I will be back at that location within a few weeks. Just wondering does a cell phone have a better ability for reception than the modem. If so I may need an external antenna. As I stated the cell tower is in visual distance probably less than a 1/2 mile away. Sits on top of a mountain.
      • Dop88's avatar
        Dop88
        Just adding cell phones get a solid 4g LTE signal.
